Activity › Forums › Square Box CatDV › Browse Catalog Process
  • Browse Catalog Process
    Posted by Warren Baker on August 17, 2011 at 3:45 pm
    Using CatDV 9 on MacPro 10.6.8.
    Open Browse Catalog. Type in a search word. The results show you what catalog contains the clip(s) with that particular search word.
    IF- the search word finds the clip where the word was part of an Event Marker descriptor or a descriptor used in the Notes area under the Log Notes tab, double-clicking on the catalog will open a blank catalog.
    IF- the search word finds the clip where the word is part of a User Setting (custom or otherwise) descriptor, double-clicking on the catalog will open the catalog correctly.
    Is this the correct behavior? Is there a setting that needs to be changed?
    Thanks.
    Rolf Howarth replied 15 years, 1 month ago 2 Members · 1 Reply
  • Rolf Howarth
    August 17, 2011 at 4:24 pm
    That doesn’t sound right. Please email a screenshot of the Browse Catalogs window after doing the search and a copy of your CatDV Error Log (which you can access via Help > System Information) to support@squarebox.co.uk so we can investigate.
