Activity Forums Adobe Photoshop Broken Pieces
  • Broken Pieces
    Posted by Joe Mcarthur on February 9, 2008 at 6:33 pm
    i need to make an image look like it has been broken into scattered pieces (3d look) . . . is there a tutorial out there for this . . . any suggestions?
    Thanks in advance
    Del Holford replied 18 years, 7 months ago 3 Members · 2 Replies
  • Mike Gondek
    February 11, 2008 at 2:34 am
    After Effects has a great shatter effect for doing this.
    Photoshop is not a 3D program, but Alien Skin makes a set of filters called Xenofx which has shatter and cracks.
  • Del Holford
    February 11, 2008 at 8:43 pm
    …and if you can’t afford the plug-ins buy a pane or 2 of glass at the hardware store or Lowes/HomeDepot, place it on a white sheet or black cloth and gently break it (them). Photograph that with your digital camera and use that photo as a layer over the image you want. Adjust lighting and transparency until you get the look you want. Be sure to clean up your mess and get all the glass off the cloth. 🙂
    Del
    fire*, smoke*, photoshopCS3
    Charlotte Public Television
    del underscore edits at wtvi dot org
