Activity Forums Apple Final Cut Pro Legacy Brodcast monitor 3000K, 6500K or 9300k
  • Brodcast monitor 3000K, 6500K or 9300k
    Posted by Shiloh Heyman on June 25, 2007 at 11:42 am
    I was hoping that somebody could shed some light on what white point to set my monitor to when color correcting, 3000K, 6500K or 9300K? Why do these settings exist?
    Shiloh
    Joseph Owens replied 19 years, 2 months ago 4 Members · 4 Replies
  • Graeme Nattress
    June 25, 2007 at 3:14 pm
    REC709 has a D65 white point, which is very closet o 6500k. 9300k is for the Japanese who like a different white point than we do. No idea what 3000k is for….
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Tom Matthies
    June 25, 2007 at 5:08 pm
    3000K can be handy if you are using the actual monitor within a shot, as a prop or an over the shoulder source on a news set, while shooting in a studio situation. The other settings will result in an overly blue image if shot with a camera that is setup for 3200K white balance. I don’t know if this is the actual use for which the 3000K setting was designed…but it works for a studio setup.
    Tom
  • Shiloh Heyman
    June 26, 2007 at 3:24 am
    Thank you very much guys. I guess I will definetly go with 6500k then. I appreciate the info.
    Shiloh
  • Joseph Owens
    June 26, 2007 at 7:47 pm
    3000 would be close to 3200K which is tungsten balance, so it would be better if you were shooting with that stock. I have to wonder if it would be good as a “projector” white point for film…
    JPO
