Activity Forums Adobe Premiere Pro Broadcast Tech specs help! I have a flicker on my GFX and can´t seem to remove.
  • Broadcast Tech specs help! I have a flicker on my GFX and can´t seem to remove.
    Posted by Harriet Davies on November 25, 2020 at 5:13 pm
    Hello,
    I have recently been tasked to send a film to a broadcaster. The video specs I was orginally sent are as follows,
    Type: QuickTime Movie
    File Size: 80.49 GB
    Image Size: 1920 x 1080
    Frame Rate: 25.00
    Source Audio Format: 48000 Hz – 24 bit – Mono
    Project Audio Format: 48000 Hz – 32 bit floating point – Mono
    Total Duration: 00:54:28:06
    Pixel Aspect Ratio: 1.0
    Alpha: None
    I need to convert this video to have 16 channels and a 29.97 framerate quicktime appleprores 422.
    TO me this seemed like a simple conversion, at which everytime I render and export there seems to be a flicker with the GFX..
    Has anyone had this problem or can give me a few tips at how I can solve this, please ask if you need more details.
    Thank you in advance!!
    H
    Harriet Davies replied 5 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
