Activity › Forums › Apple Final Cut Pro › broadcast safe filters FCPX
Posted by Richard Hall on January 2, 2013 at 11:47 amDoes anyone know if there are some 3rd party filters yet. Also any ideas on how to change the default of the standard plugin from NTSC to PAL would be great!
Neil Sinclair replied 13 years, 9 months ago 3 Members · 5 Replies -
Neil Sinclair
January 2, 2013 at 6:38 pmUsing 10.0.7. In the Inspector, on the video tab, Select Broadcast Safe, should find a Video Type option
NTSC or PAL -
Craig Russillroy
January 2, 2013 at 6:49 pmhey Richard
This filter is the best one i have seen so far,
Fcpx
10.7
FCP 7.0.2
FCPX 1.0..4
3 x 4TB Thunderbolt R4
VC100
3 x ioXT
MicroHub
Ultrascope
SmartViewCheck out the free iBook broadcast delivery 101 on itunes
http://Www.delivercommercials.com
Richard Hall
January 3, 2013 at 2:58 pmThanks Neil – had sussed that, its a pain that it always defaults to NTSC on first use with a clip and I wondered if there was a way of losing the NTSC option or forcing it to use PAL first… maybe in the system/motion templates..
Your imagination is the limitation.
Richard Hall
January 3, 2013 at 3:01 pmThanks Craig – that is cool! Good broadcast delivery guide book in ITunes btw!
Neil Sinclair
January 3, 2013 at 4:47 pmYou can create a PAL only Broadcast Safe with Final Cut Effect in Motion. Just apply the Broadcast Safe to the Effect Source and change the default to PAL. You can then choose to publish the options
you may need. Save template, category etc. You should now have a default PAL Broadcast Safe
filter in FCP X. HTH
