Activity › Forums › Apple Final Cut Pro › Broadcast quality subtitles plugin for FCP X that will pass Netflix qc
Javier Calderon replied 9 years, 4 months ago 7 Members · 27 Replies
Sybren Arnoldus
May 10, 2017 at 8:40 pmHi Javier, look here: https://gotranscript.com/subtitle-converter super easy!
About Kolibri, I like it but the last update was 2013. My guess is it won’t be updated so some day it will stop working. A bit of a gamble to buy it but not a huge loss if it stops working. Somebody should buy the source code and continue the development …
And as Andreas pointed out, Kolibri does not import / export to FCPX. -
Javier Calderon
May 10, 2017 at 8:57 pm“why the hell do you want to do them in Kolibri again?”
Well, Andreas, it appears that FCP does not export the captions in any way that is accepted by Amazon. I mean…do you know of a way to get the subtitles I created in FCP to export in such a manner as to be accepted by Amazon? If you do, then you would be a Godsend. Otherwise, all the work I did on FCP simply won’t be accepted by Amazon and I’ll have to find another way to export them so they can be accepted.
I don’t think FCP exports to .stl, right? so I’d essentially need to do another version of the subtitles using SugarFX or Kolibri right?
Javier Calderon
May 10, 2017 at 9:06 pmSybren,
Thanks much for that link. How exactly do I transfer the subtitles that I created in FCPX to a format that the Subtitle Converter tool accepts, however? Step one in the Subtitle Converter says “Upload File”…but what exactly is the file that I upload to it? I would export the subtitles that I created in FCPX presumably…right? but how would I export those FCPX subtitles to a format that the Subtitle Converter would accept?
Andreas Kiel
May 11, 2017 at 8:01 amHi Javier,
“… I mean…do you know of a way to get the subtitles I created in FCP to export …”
If you’ve read the entire thread you should know ????As mentioned by Noah and me give my X-Title tools a try.
X-Title Extractor allows to convert to .srt, .vtt, .xml (DCP), .stl and Adobe Encore.I was wrong with my note above about .stl (Spruce) – it’s not accepted by Amazon. For the formats look here:
https://videodirect.amazon.com/home/help?topicId=201979140All the tools together – X-Title Importer, X-Title Extractor and X-Title Render – are 40 Euro. The free version have limited numbers of subtitles but no water marks nor time limitation for usage. X-Title Render is free anyway.
– Andreas
Spherico
https://www.spherico.com/filmtools“He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee.” – Friedrich Nietzsche, Beyond Good and Evil -
Sybren Arnoldus
May 11, 2017 at 8:26 am.. seems like creativecow didn’t post my reply .. here is the short version:
For your situation, use Andrea’s X-Title Extractor. Works very well and saves you a ton of time.
– make a new FCPX project and paste all your subs in there.
– export the xml of this project
– open X-title Extractor and bring the xml file in there
– export the srt
– if needed, convert the srt to ttml with the online toolAndreas did a great job on the X-title tools, don’t forget to make a donation. Also to get rid of the 50 subs limitation.
Kolibri is only for subtitling outside FCPX. -
Javier Calderon
May 11, 2017 at 6:02 pmWill give that a try. Thanks very much for the info, Sybren.
