Activity › Forums › Apple Final Cut Pro › Broadcast quality subtitles plugin for FCP X that will pass Netflix qc
  • Broadcast quality subtitles plugin for FCP X that will pass Netflix qc
    Posted by Sam Lee on December 15, 2016 at 4:40 am
    I’m looking for a 100% transparent, no compromise in quality burned in subtitles plugin.
    I tried Sugar FX and unfortunately there are too many color banding noise. I couldn’t figure out why it was rejected. But after 5 attempts, the culprit was the subtitles plug in that caused video artifacts.
    It was rejected by Netflix’s qc. And after many tests, there are indeed color noise added.
    When I click on and off, I can see the subtle dithering and banding noises it added for darker, low light scenes.
    It looks like this $200 plug-in from Sugar FX is not suitable for high end mastering. Any recommendations to the high quality burn-in subtitles for FCP or other apps that will pass Netflix’s qc for burned in subtitles to the content?
    Javier Calderon replied 9 years, 4 months ago 7 Members · 27 Replies
  • 27 Replies
  • Noah Kadner
    December 15, 2016 at 4:42 am
    Is there a reason why you’re not just turning it over to a subtitling service. I’m sure Netflix has a ton of vendors that are pre-approved.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Sam Lee
    December 15, 2016 at 6:11 am
    I have very high quantity of content and want full flexbility in changes and revisions. Massive amount of hours. If it was only a few, no problem. The costs will get out of control when a small change is needed as well. Prefer to keep in house for full control.
    The only other way is a separate subtitles file. That seems to be the preferred method for Netflix, Amazon and many others. This way the video will not be subjected to more unwanted noise.
  • Noah Kadner
    December 15, 2016 at 7:33 am
  • Sam Lee
    December 15, 2016 at 2:56 pm
    OK. Thanks. Will check these out soon.
  • Brett Sherman
    December 15, 2016 at 2:57 pm
    I don’t get why you would want burned-in subtitles. I’m also not sure what 100% transparent, burned-in means. It’s a bit of an oxymoron. If it’s 100% transparent it’s not burned-in. Maybe you mean no background box. Of course if it’s burned-in you can just use Apple’s built-in title tool.
    There are many services that make subtitle files, like rev.com. But it sounds like it’s translation for a limited part of the video. In that case you might want to use something like “Subtitle Edit Pro” in the App Store and make your own.
    Brett Sherman
    One Man Band (If it\’s video related I\’ll do it!)
    I work for an institution that probably does not want to be associated with my babblings here.
  • Andreas Kiel
    December 15, 2016 at 3:13 pm
    I chime in cause Noah mentioned my X-Title tools (spherico/filmtools).
    Few things worth to mention here:
    1) SugarFX Subtitle is 99 USD.
    2) Burned-In subtitles shouldn’t cause a problem anywhere.
    3) 3rd Party companies – even if approved – normally don’t deliver rendered movies.
    So what to do? It’s a bit trial and error:
    Change subtitle color/saturation/brightness.
    Try the same with the outline.
    Try a blured and/or more or less transparent outline.
    Try a combination of the above.
    Some of the “Try … ” are easier to handle with Motion “Title” templates.
    Deliver a separate subtitle file.
    While this kind of self-promotion ☺ give X-Titles a try
    Hope that helps.
    – Andreas
    Spherico
    https://www.spherico.com/filmtools
    “He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.” – Friedrich Nietzsche, Beyond Good and Evil
  • Nick Meyers
    December 18, 2016 at 9:24 pm
    he wants the process to be transparent, with no artefacts.
    nick
  • Sam Lee
    December 19, 2016 at 4:12 pm
    Burned in subtitles are primarily for costs reason. Audio dubbing is much more costly to produce than subtitles when it’s done in high quantity.
    Come to the subject of subtitles, I don’t see Netflix, Amazon have burned in subtitles. They’re all separate on/off options and provided with a separate subtitles file. By using this, there should not be added encoder noise to the video and will pass qc.
    I also tried Sugar FX subtitles for Pr CC 2015. The transcoding took about 5-8x longer than in FCPX. The color banding still exists, but dramatically much smaller. I suspect something is not done right with the SugarFX subtitles plugin in handling this.
  • Javier Calderon
    April 28, 2017 at 6:25 pm
    Okay…So, Sam. I’m WAY late to the game here, but I just came across this thread because I’m literally having the exact same problem. I’m trying to upload my feature film to Netflix, and literally subtitled the entire feature manually myself – only to find out after I was finished with it and tried to upload an entire new movie file w/the subtitles in them that Netflix wouldn’t accept them. Now I’m searching around to try to find out how to be able to do this on my own w/o having to go to some post house that charges a pretty penny.
    Did you ever resolve how to get your captions/subtitles going in FCPX and then accepted on Netflix?
    Much appreciated.
  • Andreas Kiel
    April 29, 2017 at 6:32 pm
    If you want to submit an additional subtitle file ask Netflix for the supported formats and format specs.
    Here what I’ve found:
    https://backlothelp.netflix.com/hc/en-us/articles/215758617-Timed-Text-Style-Guide-General-Requirements
    – Andreas
    Spherico
Page 1 of 3
