Activity Forums AJA Video Systems broadcast monitor playback
  • broadcast monitor playback
    Posted by Ayman Abdel-basset on October 27, 2009 at 3:49 pm
    In my company we have many edit suites of FCP with kona LH.
    we usually face problem.
    my self didn’t face with the blackmagic..
    when we import any QT file (for example) H.264.
    then insert it in sequence of aja HD uncompressed.
    it gives red bar for render!
    when we render it and play it back!
    it doesn’t play on broadcast monitor!
    So i import this H264 (for example)into new sequence.
    then i click OK for the dialogue to make the sequence same acid of the file..
    then hit play!
    no play on broadcast monitor!
    so i found solution for it that i open the clip in QT player then RExport it to QT apple prores or any aja codec file..then it plays fine on the broadcast monitor..
    i see this is crazy especially if long time file…
    this problem happen in all FCP suites we have(4 suites)
    for any QT i put on the timeline created by codec different than prores or aja..
    (animation,none,h264,pal….)
    in the blackmagic it was not happen!
    so where is the problem??
    best regards
    |A|
    Ayman Abdel-Basset
    https://www.mbasset.com
    Abu-Dhabi UAE
    Mitch Ives replied 16 years, 10 months ago 4 Members · 20 Replies
  • 20 Replies
  • Jeremy Garchow
    October 27, 2009 at 4:32 pm
    [ayman abdel-basset] “so where is the problem?? “
    FCP does not support rt playback of codecs that aren’t supported by the suite, such as h264. h264 is a web delivery codec, not an editing codec. You need to conform all video to something that is enabled in FCPs rt engine.
    Jeremy
  • Ayman Abdel-basset
    October 27, 2009 at 5:56 pm
    Jeremy,
    thank you for your reply!
    but i guess you didn’t read all of my post..
    same problem happen when i add animation codec or any other codec than prores or aja acids..
    i gave H264 as sample..
    and FYI any codec you add on sequence it should render to the codec of the sequence and play on the broadcast monitor..
    in my case it renders..but no way to play on broadcast monitor.
    Ayman Abdel-Basset
    Abu-Dhabi UAE
  • Walter Biscardi
    October 27, 2009 at 6:28 pm
    [ayman abdel-basset] “same problem happen when i add animation codec or any other codec than prores or aja acids.. “
    Animation is not an editing codec either.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” now in Post.
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Blog!
    Twitter!
  • Jeremy Garchow
    October 27, 2009 at 7:00 pm
    Animation isn’t a real time capable codec either. You need ot place the movie in a timeloine that has a standrd video codec, render and then you should have rt playback. If oyu son’t, that’s becuase your timeline and video output aren’t matching.
    Jeremy
    October 28, 2009 at 7:45 am
    thanks for your reply..
    i do know this..
    BUT with my experience with Blackmagic when i add animation codec movie on timeline with native codec of the video card..
    it gives me red bar (which mean your say)..but when i render this it goes real time!
    because i need animation codec on timeline line for alpha..
    that doesn’t happen in the aja..
    hope you could get what i mean!!
    |A|
    Ayman Abdel-Basset
    Abu-Dhabi UAE
  • Jeremy Garchow
    October 28, 2009 at 3:30 pm
    [ayman abdel-basset] “but when i render this it goes real time! “
    RIght, so the proper way to do this is to select the proper easy setup from the easy setup menu (control-q).
    Then make a new sequence.
    Then drag one of your files to the sequence and when it asks if you want to change the sequence to confrom to the clip, you say NO.
    Then you render, then you playout in rt.
    Jeremy
    October 28, 2009 at 6:03 pm
    this is what i do..
    and it doesn’t play realtime!
    with blackmagic it plays realtime..
    it looks am not able to illustrate what i mean!…
    Ayman Abdel-Basset
    Abu-Dhabi UAE
  • Jeremy Garchow
    October 28, 2009 at 6:13 pm
    [ayman abdel-basset] “and it doesn’t play realtime! “
    Then something is not setup properly.
    Jeremy
    October 28, 2009 at 7:46 pm
    this is what i want to know…so any help will be appreciated..
    because all suites we have do this!..
    Ayman Abdel-Basset
    Abu-Dhabi UAE
  • Jeremy Garchow
    October 28, 2009 at 7:50 pm
    It’s pretty easy, Ayman. What format are you working in?
