Activity › Forums › Apple Final Cut Pro Legacy › broadcast lxf files
  • broadcast lxf files
    Posted by Johannes Johannesen on September 21, 2010 at 10:53 am
    Dear all,
    I have a query regarding delivery to broadcast on an HD channel on satelite.
    This is what they have sent me-
    We are using Harris Transmission servers, your imported material will be broadcasted on (“*.lxf” MPEG2 50 mbps, 4:2:2, 4 “audio channels 16bit”), it is recommended for the imported files to be (“*.lxf” and the format to be MPEG2 and four audio channels)
    first question – 16 bit is that really HD?
    second question – can i export this straight from fcp or do i need special software?
    thanks for your help in advance!
    J
    Craig Russillroy replied 16 years ago 4 Members · 8 Replies
  • 8 Replies
  • Bouke Vahl
    September 21, 2010 at 11:52 am
    Just google on:
    Harris LX
    And pick the top hit.
    you end up on the Cow again, and you will read a post from someone who knows, basicly tells you to go back to your client and require that they come up with something reasonable…
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Johannes Johannesen
    September 21, 2010 at 12:56 pm
    hi bouke
    thanks for getting back. i just tried googling but nothing on cow came up, in fact nothing that had to do with broadcasting… do you have a direct link please?
    thanks,J
  • Bouke Vahl
    September 21, 2010 at 1:05 pm
    https://forums.creativecow.net/readpost/8/1006431
    mind the ‘proprietary ‘ part…
    Try exporting to XDcam, you end up with a MXF file, and if you have set everything right, it should be very close to what you need.
    And since it’s Sony, probably your client will be able to work with it.
    So i would suggest that you suggest that to your client…
    Bouke
  • Rafael Amador
    September 21, 2010 at 4:10 pm
    [Bouke Vahl] “Try exporting to XDcam, you end up with a MXF file, and if you have set everything right, it should be very close to what you need.”
    Right.
    Export XDCAM 422 50Mbps and re-wrap as with FC “Export to XDCAM” option.
    As Bouke says, is basicalli what they are asking you.
    rafael
    http://www.nagavideo.com
  • Craig Russillroy
    September 21, 2010 at 5:59 pm
    We deliver a lot of commercials to broadcasters and LXF is a nightmare look at telestream episode 5 ( 6 is in pre release) this is the cheapest solution – for 1000 bucks it does all you broadcast files and a million zillion billion other files – you can get a free trial which only does 30 seconds transcode – do you do lots of sends to the broadcaster ?
    September 22, 2010 at 9:14 am
    thanks for your replies! great help. i m still a little confused though. So you are are saying I should export to xdcam file format from FCP and see what they say?
    next step would be purchasing episode or mx4mac? i read somewhere that neither were making outcomes that were any good.
    for now we are only sending 4 hour footage over every month, with it likely to increase in the next few months.
    thanks for your help!!!!
  • Bouke Vahl
    September 22, 2010 at 9:42 am
    Rafael and me are suggesting indeed just that, send them something they did NOT ask for.
    About Episode, i’ve got version 5.3.2 running, and i can’t find LXF output.
    Now from the link, it’s a ‘ proprietary’ format, and i doubt they give it away.
    But, since it’s 50 megabit Mpeg2, Sony MXF comes very close, to the format you described,
    and Harris should be the company to support that…
    (not LXF vs MXF, one letter difference, one pos in the alphabet…)
    If you don’t want to nag your client, contact Harris and ask them about your options.
    Bouke
  • Craig Russillroy
    September 22, 2010 at 10:39 am
    Hi Guys,
    I found on Rhozet Carbon Coder it is LXF and in Episode it is MXF – interesting – how about doing a 30 sec test to the TV STATION and seeing if they can accept tthe MXF …
    Adstream
    London, England
    Mac Pro – 8gig ram – FCS 3 – CS4 – Cinema 4D, Flip Factory, Rhozet, Episode
