Activity Forums VEGAS Pro Broadcast filter
  • Broadcast filter
    Posted by Roger Bansemer on December 14, 2013 at 7:26 pm
    In my video output FX above my preview window, I’ve applied a broadcast colors filter and I check it then close the window. I can immediately go back and open it again and it’s not checked!
    I’ve had this filter as part of a template. Seems if I remove it and put the filter in again, it sticks.
    Anyone know what’s happening?
    Roger
    Roger Bansemer – PaintingAndTravel.com
    Roger Bansemer replied 12 years, 8 months ago 2 Members · 2 Replies
  • Graham Bernard
    December 15, 2013 at 5:38 am
    _______________________________________________________________
    [Roger Bansemer] “I’ve had this filter as part of a template.”
    Roger, presently I can’t repro. Just to be sure in what I am doing, what do you mean “I’ve had this filter as part of a template.“? What template? A Render Template? An FX Template? And when you say it is “unchecked”, where are you seeing this change?
    Interesting – you may have stumbled on a bug.
    Cheers
    Grazie
  • Roger Bansemer
    December 15, 2013 at 2:29 pm
    Hi Grazie,
    After working with it for a while, I’ve discovered that if I totally remove the plugin from the template and then put it in again, the setting that it’s on sticks. I should have done that from the beginning. I’ve had that happen on several plugins in the past.
    It’s our PBS television template which has our intro, countdown, etc on it.
