Activity › Forums › Adobe After Effects › Broadcast composite
Broadcast composite
Posted by Paul Bibby on July 20, 2009 at 6:09 amI would like to make a composite for broadcast what is the best rez to work in.
Paul Bibby replied 17 years, 2 months ago 3 Members · 3 Replies -
Michael Szalapski
July 20, 2009 at 6:30 amThat depends on the country in which you plan to broadcast as well as what the format for which the end product is intended. HD? SD? PAL? NTSC? There are lots of broadcast options. It depends on the requirements of the station/channel for whom your product is being made.
Standard Definition (NTSC) in the US is 720×480, 29.97 fps with 0.9 pixel aspect ratio. However, many stations prefer other formats. Some want 720×486, many are now HD, and tons of other considerations.
Basically, what I’m trying to say is, ask them.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Todd Kopriva
July 20, 2009 at 1:57 pmMichael is right, but I’d go even one step beyond “ask them”. Make sure that you confirm the delivery specifications with the client, preferably with a test clip that they confirm is acceptable. If you want to get paid at the end of your work, leave nothing to assumptions and guesswork at this early stage.
Some of these sorts of concerns are outlined in the “Planning your work” section of After Effects Help, but by far the most valuable advice is in the article by Aharon Rabinowitz that that section links to back here on the COW.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
Paul Bibby
July 20, 2009 at 2:03 pmThanks man I am doing quite a bit of planning the job isn’t even signed off yet just doing research thanks for all the advice guys
