Activity › Forums › Apple Final Cut Pro Legacy › bringing up backlit subject
  • bringing up backlit subject
    Posted by David Mcguire on July 20, 2009 at 4:07 pm
    Im looking for a way to bring a face out against a bright background. The subject was shot against a window. I can bring it up some with 3 way color corrector but its not enough. The subject is in focus and had two lights but was overpowered.
    Is there a spot light effect to bring the face into more light?
    thanks
    David McGuire
    Seastewards.org
    Media for a Healthy Ocean
    Ken Jones replied 17 years, 2 months ago 6 Members · 6 Replies
  • John Fishback
    July 20, 2009 at 4:35 pm
    You can create a vignette in both Colorista and Apple Color to do what you want. If you need the vignette to track as the subject moves, Color is the easiest. You can keyframe Colorista, but that can be painful if there’s a lot of movement. Also, in Color you can define the vignette’s shape, while Colorista only gives you a circle/oval or rectangle.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Stu Siegal
    July 20, 2009 at 5:11 pm
    Google Lyric Shadow Highlight filter – a free plugin that does wonders in these situations.
    http://www.verite-media.com
  • Ken Jones
    July 20, 2009 at 8:14 pm
  • Harry Bromley-davenport
    July 21, 2009 at 2:46 am
    I have a plug in called SPOTLIGHT. I believe that this was part of the original FCS package and not one that I purchased.
    I suggest digging through your plugins. I use it frequently and it’s great and easy to track with.
    Best
    Harry
  • Max Frank
    July 21, 2009 at 7:31 am
    This is the secret weapon – brilliant and cheap:
    Face Light Plug in from: https://www.haiku.com.au/
    Wayne
    osx 10.4.8 G5 2.0DP, 3.5GB RAM, FCP 5.1.2
  • Ken Jones
    July 21, 2009 at 3:32 pm
    Those plug ins are excellent. Very quick and easy.
