Activity Forums Adobe After Effects Bring The Imported Assets to view, after enabling 3D
  • Bring The Imported Assets to view, after enabling 3D
    Posted by Mohsen Saeedi on January 12, 2019 at 2:11 am
    Hello my fellow artists, Happy holidays
    One Issue that I have in after effect is when I import a new layer to my comp and make it 3D, it goes off camera because I’ve already moved the camera away.
    It’s not actually a problem and it should be like that, But for a repeating task like this It become tedious to zoom-out and nudge the layer to the current view over and over again!
    I Really hope someone has already found a solution for this. If so, I hope to know.
    Mohsen Saeedi replied 7 years, 8 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    January 12, 2019 at 7:23 am
    You could make a 3D null in view and shift-parent the layer to it once you’ve made it a 3D layer, which snaps the layer to the location of the null. Then unparent without shift.
    Senior Graphic Designer
  • Mohsen Saeedi
    January 12, 2019 at 8:58 am
    That seems like a solution, when you parent a null to the camera so when animated, the null will move with the camera, it can be used as a locator by shift parenting.
