Activity Forums Adobe Premiere Pro Brightness/Contrast Automation Not Recognized in PPro CS5.5
  • Brightness/Contrast Automation Not Recognized in PPro CS5.5
    Posted by Andrew Hoag on April 19, 2012 at 3:48 pm
    I’m working on a TV show right now and have made a “Ramp Up” preset using the Brightness & Contrast filter in PPro CS5.5. It ramps from 0 -> 50 for both parameters, and the automation is perfect. However, on the clip following I’ve tried to make a “Ramp Down” preset using the same filter but with the automation inverted going from 50 -> 0 for both parameters. PPro doesn’t recognize this automation and past the “0” keyframes the filter is still displaying on the clip as if it were at 50.
    I’ve tried restarting and moving the parameters around on the clip to no avail. Has anyone else had this problem? (With any filter in PPro, not just Brightness / Contrast.)
    Thanks in advance.
    Andrew Hoag replied 14 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
