Activity Forums Apple Final Cut Pro Legacy Brightness/chroma shift when subtitle in on in FCP
  • Brightness/chroma shift when subtitle in on in FCP
    Posted by Kazumi Hatori on July 17, 2010 at 3:33 pm
    As title said,
    I find the video’s value is changed when subtitle is over it.
    And I find the scope, it’s beyond 100 after add subtitle, when it’s not with no title.
    In video, it’s significant the Red thing turned to Redish Orange,
    why does this happen?
    I’m editing with Prores 422 in 1920×1080 25p.
    And the problem becomes more serious when exporting to MPEG-2.
    Kazumi Hatori replied 16 years, 1 month ago 3 Members · 4 Replies
  • Jeremy Garchow
    July 17, 2010 at 5:39 pm
    Are your titles superwhite?
  • Neil Sadwelkar
    July 18, 2010 at 5:13 am
    Which version of FCP, QT, and MacOSX? And, are the titles from FCP, or imported graphics (for eg. .jpg, .png, .tif, .tga) or some other?
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • Kazumi Hatori
    July 18, 2010 at 5:31 am
    first it’s pure white lightness 100% and have black stroke,
    then I tried tune it to grey…….and problem is still here.
    I’m using FCP 7, iMac with OSX 10.6.2, Quicktime should be most updated one (installed quicktime player 7.6.3 and the default 10.0)
    thanks!
  • Kazumi Hatori
    August 3, 2010 at 4:56 am
    I just found the problem comes up when I export the current movie.
    And I should revise that, after I add titles, the output clip have a brightness/chroma shift in “no title area”, when titles pop up, the video turns to normal.
    Then I chose “send to -> Compressor” to output quicktime movie(same as sequence: Prores 422), and the problem has gone!
    It’s awesome but I still wonder what could cause that shift happen?
