Activity Forums Apple Final Cut Pro Legacy Brightness and contrast effect flickers
  • Brightness and contrast effect flickers
    Posted by Brent Van den abbeele on March 3, 2010 at 5:53 pm
    I have a big problem, I used a brightness and contrast effect in my project. And it turns out that it flickers after rendering (and also before rendering when scrolling frame by frame through the timeline). My project has to be exported within 3 hours and it has to be with more contrast. What can be the problem, do I have to start all over in an other way?
    We shot on Red. I’m working with FCP 7.
    In the bright and contrast filter i used settings: brightn. 0 and contrast 16.
    It’s a random flicker, not the whole time the same…
    Thanks in advance
    Brent
    Brent Van den abbeele replied 16 years, 5 months ago 3 Members · 5 Replies
  • Arnoud Delporte
    March 3, 2010 at 6:05 pm
    I’m not near my Mac, but two ideas off the top of my head:
    1: does a shift fields filter make any difference?
    2: how about a slightly different setting for the effect (shouldn’t be necessary, but if it works…)
    Greets,
    A.
  • Brent Van den abbeele
    March 3, 2010 at 7:10 pm
    Thanks for the fast answer but the Shift fields filter doesn’t work, and i tried with different settings but that doesn’t work either.
    March 3, 2010 at 8:03 pm
    I solved the problem by creating the contrast with the 3way color corrector and sometimes the magic bullet misfire contrast effect. This seems to work for now. I’m still re-grading the whole sequence…
  • Scott El haney
    April 19, 2010 at 2:58 am
    Brent, I had the same problem and that fixed it perfectly! Thanks!
    April 19, 2010 at 9:15 am
    Glad I could help.
    Brent
