Activity Forums Apple Final Cut Pro Legacy Bridging FCP and AVID / AE
  • Bridging FCP and AVID / AE
    Posted by Sascha Engel on July 13, 2010 at 5:16 pm
    Hi Everybody,
    a friend of mine edited a music video on AVID and asked me to do some corrections and gradings.
    I want to import the the file into FCP – but I DO NOT have Automatic Duck – unfortunately 🙁
    So, my usual procedure in this case is to import the whole edited clip, rendered out from AVID – put it back on my FCP timeline and then chop it up again in individual clips, which I can then work on with Magic Bullet or in COLOR.
    Is there any other less complicate way – without involving the Duck or this is as good as it gets?
    Thanx for any thoughts on that.
    Greetings,
    Sascha
    Matthew Bradshaw replied 16 years, 1 month ago 3 Members · 4 Replies
  • Sascha Engel
    July 13, 2010 at 5:26 pm
    Not really, AVID can’t export XML files, ate least not the version of AVID they worked on.
    I would get it as a MOV Quicktime File – either in DV-Pal compression or uncompressed.
  • Shane Ross
    July 13, 2010 at 5:36 pm
    If you lack the Duck that allows FCP to access the cut with transitions and individual media, then the only other alternative is to export a QT, import that into FCP (Make sure you have the Avid codecs installed), chop chop chop, and then grade.
    Shane
  • Sascha Engel
    July 13, 2010 at 5:45 pm
    I thought so – just hoped for a miracle.
    The Duck would be awesome, but is not in the budget at the moment.
    Thanx Shane!
  • Matthew Bradshaw
    July 13, 2010 at 6:04 pm
    There is a very laborious way to go from avid to after effects which I think would work with fcp too. Check out https://www.wesplate.com/helpful/avid_to_ae/index.html
    Matt.
