Activity Forums Apple Final Cut Pro Legacy Brand new Dual DVI lcd monitors, right one yellow tint…
  • Brand new Dual DVI lcd monitors, right one yellow tint…
    Posted by Dom111 on July 19, 2006 at 11:00 am
    I’m running 2 new 20.1 inch Formac Gallery 2010 Platinum monitors on a Quad G5 with a Nvida Geforce 7800GT gfx card.
    The second monitor has a slight yellowish tint, these are brand new out of the box monitors and on swithching the monitors around the righthand monitor still has a yellowish tint.
    Anyone had similar issues with dual displays? Is there a utility other than the basic color calibration within the monitors utility?
    Thanks in advance,
    Dom.
    Dom111 replied 20 years, 1 month ago 5 Members · 6 Replies
  • Walter Biscardi
    July 19, 2006 at 11:03 am
    [dom111] “Anyone had similar issues with dual displays? Is there a utility other than the basic color calibration within the monitors utility?”
    We’re running a 20″ Viewsonic and 23″ Apple display on the stock Quad graphics card with no issues. usually the displays come with some sort of calibration utility, though few of them are for Mac.
    Walter Biscardi, Jr.
  • Mark Maness
    July 19, 2006 at 1:58 pm
    Mixing monitors, to me, is like mixing drives. You know, like mixing a RAIDed Firewire drives with SATA RAIDed drives for doing video editing. You’re bound to run into trouble sometime. As for the same monitors not matching, that’s something else that has to be dealt with.
    All monitors are like computers, no two are exactly the same. And there is no way to get them to match exactly by using the little calibration programs that come with them. Your only option to make them match is a calibrator device. Pantone make one called the “Huey” for less than $90 and it works flawlessly on my PCs. I’m not sure about the Macs but I would have to say that it would work just as well as it does on the PC.
    Give that a shot, and I’m sure your color issues will go away.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • 13 Create COW Profile Image
    13
    July 19, 2006 at 3:29 pm
    Another option before you run out and buy a calibration device
    I am guessing that the asjusting you have done is with the immage controls on the monitor itself. If you go into system preferences under display you can do some color calibration there also
  • Rennie Klymyk
    July 20, 2006 at 5:12 am
    [dom111] “Is there a utility other than the basic color calibration within the monitors utility?”
    Looks like you have been there. The graphics card is the next suspect in the equation. Do you know anyone around with a dual head card you can connect your monitors to or better yet, swap cards with to test.
    “everything is broken”
    13
    July 20, 2006 at 5:56 am
    Yea wasnt shure if he was refering to OSX’s utility or the controls on the monitors them self.
    I would doout it would be the graphica card though, but try swapings the monitors to the oppisite DVI conection on the Graphics card. If the one with the yellow tint still has it, then it is not the card.
    I have two identical LCD screens myself and there is a slight difference between the two
  • Dom111
    July 20, 2006 at 11:31 am
    thanks for the suggestions, looks like I’ll have to grin and bear it…
    Dom
