Activity › Forums › Adobe After Effects › Brainstorming! DREAM Sequence.
  • Brainstorming! DREAM Sequence.
    Posted by Michele Poggi on February 12, 2012 at 10:42 am
    I’m going to work for a Short movie (with friends and with an academy’s stuff so nothing money/work related) that has as the Main scene a Dream sequence.. Dream that will, it seems, be fairly long. So.. I’d love to, for the first time, try to engage a discussion with you all about what I could try to make it interesting/cool/whatsoever.
    Have you ever worked on something like this? What ideas come to your mind? I have a couple of mine, but before so I’d really like to hear you. 😉 I still don’t know how much strong effects will have to be, but that’s even better, we can have all sorts of things caming out of here.
    “Freelance Post-Producer”
    Editor Video
    Graphic Designer
    Digital Compositor
    Mail: snm.poggi@gmail.com
    Mobile: +39 3349129191
    Skype: sabakunomaiku
    Kevin Reiner replied 14 years, 7 months ago 4 Members · 3 Replies
  • Chris Wright
    February 12, 2012 at 11:52 am
    sounds like you’ll have some creative fun on this project. Here’s a few ingredients I got off the top of my head.
    change the framerate, change the playback speed, add glows to the highlights, slower shutter for heavier blurs, mix previous frames together, rotate colors, new stylistic camera angles/editing, change focal length, new gels,
  • Tudor “ted” jelescu
    February 12, 2012 at 8:20 pm
    Shoot high speed if possible to be able to have true slow motion.
    Use wide angle lenses in production and strange camera angles.
    Using glows on highlights is a great way to visually point out that it is a dream sequence – just make sure you work in 32bit for best glow effects. Also you can double that with a Channel Blur on the Red.
    A tilt shift in post may help.
    An overall color grade that will be distinctly different than the rest of the piece will help.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Kevin Reiner
    February 13, 2012 at 4:30 pm
    In addition to time effects, a nice and simple adjustment layer with a g-blur, curve adjustment, and vignette mask is a good place to start.
    Also, if possible, do some test shoots. That way you never say:
    “Oh, if only we shot it like this!”
    -Reiner
    Mac Pro 2 x 3 GHz 6-Core Intel Xeon
    32GB Memory
    Dual-channel 4Gb Fibre Channel PCI Express card
    Dell Display (23″ flat panel)
    ATI Radeon HD 5770
    AJA Kona LSi SD/HD capture card
    Rourke 16 TB
    Flanders 2460
    SOFTWARE
    Mac OS X 10.6.5
    FCP 7
    After Effects CS5
    Boris Continuum
    Sapphire Plug Ins
    All Trapcode Plugs
    Zaxwerks Invig
