Brainstorm: Why might a Samson LM10 microphone not work with a GTD audio body pack transmitter (comparable with G787L receiver unit)?
Hey all,
I have an upcoming shoot this weekend (4/25-4/26 2015 for you future people) in which I was hoping to use some recently purchased Samson LM10 mics (TA3 connector) with my GTD G787L system, but the LM10 doesn’t produce any signal when connected into the transmitter. I know it’s probably not the mics themselves, as I tired out another one of the LM10s that I had just purchased with the same results. I know it’s probably not the transmitter, since I plugged one of the lavs that came with the system into the unit that wouldn’t give signal with the LM10 and got normal levels.
Impedance for the LM10 is listed as 2000 ohms, but the transmitters are listed as 1M ohms. Since I believe the rule is that you must go from low ohms on your mic to high ohms down the signal path, this seems to not be an issue (unless I’ve got the rule reversed). Finally, the GTD manual says that the connector on the transmitters is wired in the traditional 1 – ground, 2 – positive, 3 – negative arrangement, so, unless Samson has been playing around with their wiring for propriety’s sake, this also wouldn’t be a problem.
Any other ideas as to what the problem is, other than the grade of gear itself *?
*Note: I’m doing what I can here to preempt the snark about buying cheap gear. I’ve just haven’t got the time or budget to run out and replace it all. Any helpful advice would be much appreciated.
