Activity Forums Boris FX Box Set vs. BCC 7 for Sony Vegas Pro 10
  • Box Set vs. BCC 7 for Sony Vegas Pro 10
    Posted by Ray Gralak on November 30, 2010 at 10:29 pm
    I have been a light user of Vegas Pro from way back to Version 1. I have upgraded through almost every version of Vegas including recently upgrading to V10 from V9. I usually just do 2-3 short videos (<10 mins) a year so I’m not a heavy user.
    It looks like BCC 7.03 has some nice tools and I am strongly considering taking advantage of the December discount and purchasing it. However, today is the last day for the Box Set special, which is $400 more. Is there any reason I should consider the Box Set? Or, considering I am not a heavy user should I just stick with BCC 7?
    Thanks in advance,
    -Ray
    Peter Mcauley replied 15 years, 9 months ago 2 Members · 1 Reply
  • Peter Mcauley
    December 3, 2010 at 2:25 pm
    Hi Ray,
    I guess it all depends on what tools you need to complete your work. The box set includes some high-level compositing software (Boris RED) that can be used inside of Vegas as a plug-in or in standalone mode, where you render out host independent movie files. So if you are only looking for the plug-in power of BCC then you’re probably good to go with BCC however, if you need to do any real compositing such as rotoscoping, spline masking, multi-page text scrolling, charts, vector shapes, etc etc then you should go for the box set because in all honesty is it a serious bargain.
    Cheers,
    Peter.
