Activity › Forums › Adobe After Effects › Bourne flashback effect
Posted by Ian Smith on December 17, 2007 at 6:19 pmHey guys!
I have a question about how to get the effect that is used in the Bourne Ultimatum. Its during the flashback scenes, and it is like light and brightness from behind the acotrs is leaking thru and spilling over them. It moves in sync with the actors movements, and seems to be taking properties from what is happening on screen. Does anybody have any tips on how to get an effect like this?
Many thanks for any tips!
Ian Smith replied 18 years, 9 months ago 4 Members · 6 Replies -
Darby Edelen
December 17, 2007 at 9:18 pmI’m not familiar with the effect, but try this:
-Create a new Adjustment Layer, place it at the top of your layers.
-Add a Box Blur to the Adjustment Layer with Iterations at least 3, choose a Radius that looks good to you and enable ‘Repeat Edge Pixels.’
-Change the Adjustment Layer to the ‘Add’ Blend Mode.
-If there is too much light blowing out you can optionally add a Levels effect to the Adjustment Layer and increase the Input Black value. If there is not enough light blowing out you can decrease the Input White value.
Darby Edelen
Designer
Left Coast Digital
Santa Cruz, CA -
Jeremy Allen
December 17, 2007 at 11:33 pmI haven’t seen the movie, but from your description, I think something like this might get you pretty close…
https://library.creativecow.net/articles/armstrong_trent/lensflare.php
Darby Edelen
December 18, 2007 at 4:47 am[Jeremy Allen] “I haven’t seen the movie, but from your description, I think something like this might get you pretty close…
https://library.creativecow.net/articles/armstrong_trent/lensflare.php“
This tutorial deals with more localized lighting effects (a point source), where as I think the effect Ian described is a more global effect, especially considering the way he describes the effect ‘taking properties from what is happening on screen.’
I’d like to put together a tutorial on using Adjustment Layers for effects like this as well as color grading, hopefully I can find sometime to make that a reality in the coming weeks =)
Darby Edelen
Designer
Left Coast Digital
Santa Cruz, CA -
Ian Smith
December 18, 2007 at 10:30 amThanks for the feedback guys I will give what you have suggested a try, and look forward to that tutorial!!!!!
Any other comments in the meantime, would be most appreciated!
Ian
Aharon Rabinowitz
December 19, 2007 at 3:22 pmI saw the movie 2 nights ago, and thought about it when I was watching it. It was basically a duplicate layer of the footage with only the brightest points stretching vertically.
Do this:
– duplicate the layer
– give it a levels effect
– increase the Input Black (so that you have almost no light points in there) Don’t be afraid to crank this up rel high – you want it mostly black
– give it a fast blur effect set to vertical only
– set it to the Add transfer modeFor extra points, add an adjustment layer on top of everything, and then play with different color correction effects to tint it greenish.
Aharon Rabinowitz
Email: arabinowitz (AT) yahoo (DOT) com
All Bets Are Off Productions, Inc.
Creative Cow After Effect Podcast
Internet Killed the Video Star: A Guide to Creating Video for the Web -
Ian Smith
December 20, 2007 at 10:43 amwoop woop!
Worked a treat, great!
perhaps you could help me with a related problem?? 🙂 >>>>
https://forums.creativecow.net/thread/2/923592
many thanks for your help!
Ian
