Activity › Forums › Zaxwerks › Bounding Box Question revisited…
  • John Dickinson
    March 30, 2006 at 1:49 am
    This zip won’t open on my system. Are you applying ProAnimator to a comp-sized solid?
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Betty Boop2
    March 30, 2006 at 2:05 am
    Hi John,
    I was hoping that you might answer. Here is a link that should work…
    https://www.jtdesign.org/AmericasBest/Downloads/DaVinci-2.zip
    Ys, I was applying Pro animator to a comp-sized solid.
    Jay Thompson
    Thompson Visual Design & Storytelling
    7 Marjean Ct.
    Kirkwood, MO 63122
  • John Dickinson
    March 30, 2006 at 2:13 am
    Well it looks okay to me, nothing looks cropped off… Why did you precompose the solid before applying ProAnimator?
    JD
    John Dickinson
    Motionworks
  • John Dickinson
    March 30, 2006 at 2:21 am
    Okay, I notice that you’ve applied to ProAnimator to a precomposed solid inside DaVince-type. The precomposed solid is 720 x 486 but DaVince-type comp is 1620 x 824. So that means you AREN’T applying ProAnimator to a comp sized solid, if you were the solid would need to be 1620 x 824. One way around this is to activate the Collapse Transformations button for the ProAnimator layer inside the DaVince-type comp, this will extend the boundaries of the layer.
    John Dickinson
    Motionworks
  • Betty Boop2
    March 30, 2006 at 3:18 pm
    Thanks John. I’ll try that.
    Jay Thompson
    7 Marjean Ct.
    Kirkwood, MO 63122
