Activity Forums Adobe After Effects Bottom of the stack vs ambient light
  • Bottom of the stack vs ambient light
    Posted by Philip Hogarth on August 6, 2011 at 9:49 am
    Hi people,
    I have not used After Effects a lot before and not regularly but I have got a problem concerning ambient light. I am doing a 3D project which includes a basement which leads to stairs connecting to a city. I have used an ambient light for the basementhowever I have had to place the city at the bottom of the stack otherwise the view is wrong. Because of this the city falls under the ambient light as well. I have tried to precomp the basement and add the light to this but it doesn’t recognise the light and the walls are greyscale. I was wondering if there is a way to stop the ambient light affecting the bottom layer.
    Phil
    Philip Hogarth replied 15 years, 1 month ago 2 Members · 4 Replies
  • David Johnson
    August 6, 2011 at 1:59 pm
    Turn off the “accepts lights” property of the 3D layer?
  • Philip Hogarth
    August 6, 2011 at 2:37 pm
    I tried that and there is no change, I also tried turning off the adjustment switch but this has no effect on the composition whatsoever.
  • David Johnson
    August 6, 2011 at 3:32 pm
    Hmmm … I’m on a laptop without AE at the moment so I can’t check … maybe I recalled wrong and “accept lights” doesn’t apply to ambient lights or something … sorry.
  • Philip Hogarth
    August 6, 2011 at 3:36 pm
    Not at all mate, just grateful for any help. If I precompose the basement layers and add the light in there it fine. Then when I go back to my main comp it is correct until I turn on the 3D layer switch and it goes back to greyscale. Thanks though.
