Activity Forums Apple Final Cut Pro Legacy Boris titles: FCP 5.0.4
  • Boris titles: FCP 5.0.4
    Posted by Christopher11 on April 18, 2007 at 4:40 am
    Hi! I am using FCP 5.0.4., and excited to start titling in my new FCP project.
    I would like to do this from within FCP project, adding text clips to the Timeline. When I do it with the FCP text function though (Legacy Text function), they look not so great when I render to QuickTime.
    My understanding is that there should be something called Boris in the Generators menu… but I do not have it.
    I downloaded the fix from Boris, and started FCP with caps lock on, etc, as indicated, but still don’t see it in Generators. I only see things like Text, Slug, etc.
    Anyway, that fix was for 5.1 and beyond, I think.
    Is there a way I can use Boris for titling, or is it just not installed in my version?
    Please also tell me: can I use LiveType to create titles from within FCP, as I want to do? If so maybe I should just skip right to that?
    Thanks so much!
    Christopher11 replied 19 years, 4 months ago 3 Members · 6 Replies
  • David Roth weiss
    April 18, 2007 at 5:22 am
    https://www.rippletraining.com/movies/Free%20Downloads/fcp_text_hilite_960.mov
    Check out the tutorial above, it will show you what you want and more…
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Chris Poisson
    April 18, 2007 at 1:32 pm
    In FCP 5, the Boris generators have their own folder, look above the text generators.
  • Christopher11
    April 18, 2007 at 2:37 pm
    Chris, thanks so much for responding. I apologize for being a newbie, but can you give me an idea exactly where? If I open Viewer for a clip with text on it (Legacy Text), Boris should be in there? I don’t see it.
    Can you tell me exactly where I should find Boris titling function? Thanks so much.
  • Christopher11
    April 18, 2007 at 2:49 pm
    David, this is a wonderful tutorial, but Boris isn’t an option when I go to my Generators menu as he does in the video. Ouch! How do I get it there? I’m using FCP 5.0.4
    Thanks so much.
  • Chris Poisson
    April 19, 2007 at 4:49 am
    Under the generator puldown in the viewer, in alphebetical order. Should be a Boris folder.
  • Christopher11
    April 19, 2007 at 2:07 pm
    Thank you, but that’s why I’m writing you! That folder is not visible. Do you know how to make it show up?
    Thanks so much!
