Activity › Forums › Media 100 › Boris Red GL Interacters disappearing act
  • Boris Red GL Interacters disappearing act
    Posted by Jim Brodie on October 18, 2010 at 11:12 am
    Boris,
    I have Media 100 Suite 1.5.1 and when I use Boris Red’s titling function the GL Interacters disappear and never show up again. I had been working without them for a long time, wondering why they were no longer functional. I had checked that all the preference settings that would influence the GL Interacters were correct and turned on but they persisted in remaining invisible/inoperable. I had phoned Boris Support but they could not seem to figure it out either. The GL status of my video card when checked is good so obviously the drivers were fine. The only solution I stumbled upon was to trash the Red preferences. That worked. The problem is that the the GL Interacters still disappear and stay permanently unavailable if I need to construct some graphic word titles. There must be some simple solution to this mystery that doesn’t require me to trash the prefs each time. Thank you in advance for any further insight you might be able to provide into this frustrating problem.
    Cheers,
    Jim
    Michael Slowe replied 15 years, 11 months ago 3 Members · 11 Replies
  • 11 Replies
  • Floh Peters
    October 18, 2010 at 5:31 pm
    Hmmm, not sure what you mean by Red GL Interacters. Could you try to describe your issue, or maybe post a screenshot?
  • Michael Slowe
    October 18, 2010 at 9:44 pm
    I’m not sure what he means either but what disappears for me are the arrows that enable me to place a title elsewhere in the frame other than the centre where it goes automatically when typed. I have the greatest difficulty in getting a title exactly where I want it, it used to be easy to drag, now it ain’t.
    Michael Slowe
  • Jim Brodie
    October 19, 2010 at 12:26 am
    Thank you for responding. Clarification I’m referring to the
    Open GL Interactor that are the red, blue and green arrows in the picture below. They control the x,y,z positioning of material in Red’s composite window. They would disappear and not return unless I blew out the preferences.
    Michael, you can increase the speed of operations within the composite window if you degrade the preview resolution to 50 or 25% resolution. This greatly increases the responsiveness of your operation here.
  • Jim Brodie
    October 19, 2010 at 12:30 am
    I’ve attached the still showing the Open GL Interactor
  • Jim Brodie
    October 19, 2010 at 1:51 am
    Michael,
    I reread your post and I think you are referring to what I was talking about… the arrows (Open GL Interactors)were there, you actually see them flash up in the composite window for a fraction of a second when M100 loads Boris Red and then they’re gone! You are left with only a little box to move objects around which is a pain. The Interactor arrows are a very intuitive and useful tool.
    Try trashing you’re Boris Red prefs in User/Library/Prefs/Boris Red Prefs and they’re back. Its the only work around I’ve found that brings the arrows back!
  • Floh Peters
    October 19, 2010 at 10:29 am
    For me the arrows disappear as soon as I turn on the “auto update monitor” in the “Preview” menu. I think this is related to not being able to use the OpenGL preview directly to the Kona card. Or maybe it is a bug…
  • Michael Slowe
    October 19, 2010 at 2:12 pm
    Yes, this is EXACTLY what I am also having trouble with. I need these arrows accurately to position my text over the background scene. Floh, is there anything we can do and does Boris know?
    Michael Slowe
  • Jim Brodie
    October 19, 2010 at 2:50 pm
    Floh,
    Thank you for your response. I use the Kona LHe card and the latest versions of Mac OS and quicktime.
    Cheers,
    Jim
  • Floh Peters
    October 20, 2010 at 9:20 am
    According to Boris this is a bug within Red which they have reproduced, and it happens with or without Media 100. As a workaround you could turn off the “Auto Update Monitor”, which should bring back the arrows.
  • Jim Brodie
    October 20, 2010 at 2:59 pm
    Thank you Floh for getting to the bottom of this.
    I’m sure it will reduce the frustration and boost the productivity
    of a lot of M100 users out there.
    Cheers,
    Jim
