Activity Forums Boris FX Boris RED as a DaVinci Resolve 15 OFX plugin?
  • Boris RED as a DaVinci Resolve 15 OFX plugin?
    Posted by Kuhnen Brown on December 30, 2018 at 2:12 am
    Can Boris RED 5.5 be installed as an OFX plugin to DaVinci Resolve 15?
    Thanks.
    Jon Kozenko replied 7 years, 6 months ago 2 Members · 1 Reply
  • Jon Kozenko
    January 3, 2019 at 7:05 pm
    Hello Kuhnen,
    I believe Resolve 15 uses the same OFX plugin directory, so the same Resolve install option for RED should install RED into this version of Resolve. However, I took a look at RED inside Resolve 15 with an associate, and we found a notable problem with the coloring of the footage; the interface appeared to operate as normal, but this color problem might appear on your end as well. RED has gone Legacy so if this problem appears on your end as well, you might need to use RED as either a standalone Engine or within an earlier Resolve version, like 11 or 12. Having said that, most of the RED functions have been ported over to our Continuum product, which does fully support Resolve 15, so I would recommend taking a look at Continuum OFX 2019 if you have not done so already.
    Thank you.
    Jon
