Activity Forums Boris FX boris red 5.1.3 and vegas pro 11 – PAL
  • boris red 5.1.3 and vegas pro 11 – PAL
    Posted by Wilfried Van on March 15, 2012 at 6:17 am
    Finally red recognises the 1440×1080 vegas footage right .
    3 second m2t file -> apply boris red as plug-in of vegas
    press play in red -> after going once through the 3 sec clip , boris red plays the clip at too high frame rate ( double frame rate ? )
    ( ram preview -> right frame rate )
    go into project settings and cross manual setting , put HDV 1440×1080 25 ( although red knows it is custom 1440×1080 25 and shows as such )-> plays at right frame rate
    return to vegas ( with cancel in red ) and go back into red -> plays again at too high frame rate -> project settings and uncross manual settings -> plays right frame rate .
    Each time red is launched as plug-in of vegas , have to go to project settings in red and cross ( or uncross when crossed )and kind of re-confirm it is 1440×1080 25 , otherwise is plays the clip at too high ( double ? ) frame rate. ( ram preview is always at right frame rate )
    Bizar
    Wilfried Van replied 14 years, 2 months ago 2 Members · 4 Replies
  • Peter Mcauley
    March 15, 2012 at 1:25 pm
    Hi Wilfried,
    Thanks for reporting this – we’ll try to reproduce it in our labs and if we can reproduce it here then there’s a good chance that we can fix it.
    Peter.
  • Wilfried Van
    March 15, 2012 at 2:51 pm
    Thanks Peter ,
    Hopefully we once get the basics working for PAL HDV and PAL DV ( when old material needs updating )
    Wilfried
  • Wilfried Van
    April 4, 2012 at 7:57 am
    Hi Peter ,
    Were your labs able to look into this and if so , could you reproduce it and if so , is there to be expected a remedy ?
    Best regards
  • Wilfried Van
    July 5, 2012 at 1:12 pm
    RED whatever 5 version still playing PAL clip much too fast when RED being used as plug-in of vegas . ( as described here below or above )
    Gave up on this BORIS RED( how long is version 5 now released ?? ) and bought the adobe production premium CS6 suite instead at a good price .
