Activity Forums Apple Final Cut Pro Legacy Boris Red 3 in FCP 512
  • Boris Red 3 in FCP 512
    Posted by Alan Lacey on February 4, 2007 at 9:31 am
    I running FCP latest update on a non Intel G5 dual 2.5 and can’t get my Boris to work.
    Will I ever be able to acheive this or do I have to ug Boris to 4? I’ve done a search on this forum and things don’t look very straightforward.
    A muttonhead thanks you for any help given.
    Alan
    Alan Lacey replied 19 years, 7 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    February 4, 2007 at 1:01 pm
    My guess* would be you need to upgrade… might contact Boris directly… they are pretty reponsive.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Alan Lacey
    February 4, 2007 at 6:48 pm
    Thanks Jerry,
    I’ve fixed it via info on the Boris site.
    You have to jump thro’ a lot of hoops like running a patch, deleting pref files, then firing up FCP with caps lock on – quitting the fcp with caps lock off. Problem seems to recure frequently as well with the Boris ‘options’ button disappearing. But at least I know how to fix it now.
    Also B’s transitions don’t work but I understand there’s another workaround for that. For some reason Boris are not making the relevant pdf available to us easily for download.
    Regards
    Alan
  • Steve Eisen
    February 4, 2007 at 10:32 pm
    There are a few postings on the Boris FX forum regarding this issue.
    Red 3 transitions WILL work on FCP versions prior to 5.11.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Alan Lacey
    February 5, 2007 at 4:40 pm
    thanks Steve
    Alan
