Activity Forums VEGAS Pro Boris FX communication work better in Vegas 7?
  • Boris FX communication work better in Vegas 7?
    Posted by David Shirey on October 26, 2006 at 9:35 pm
    I tried Boris FX in Vegas 6 and the problem it had is that when you make a transition between two clips of any length, then enter boris and choose which effect, you have to specify the exact length because it always defaults to one second. If you then return to vegas and change the length of the transition Boris just renders the original length then creates a still image for the remainder. I talked to Boris and they said it was a problem with Vegas, that it just didn’t relay the transition length to the Boris plugin.
    My question is does anyone here use Boris FX and is that fixed in Vegas 7? I’d love to start using Vegas on a regular basis at work but that one issue really hinders my efficiency. Thanks in advance!
    -dave
    Edward Troxel replied 19 years, 10 months ago 2 Members · 1 Reply
  • Edward Troxel
    October 27, 2006 at 3:01 pm
    My guess is that the interaction is exactly the same. I have not tested it but have seen nothing that would indicated otherwise.
    Edward Troxel
    JETDV Scripts
