Boris FX 9 work with Premiere CS4 Windows?
Posted by Art White on October 27, 2009 at 9:56 pmDoes Boris FX 9 work with Premiere CS4 Windows? If not, what do I need to do to get in up and running? It has been a while since I have done any editing and FX 9 use to work well with Premiere Pro.
Thank you
ArtArtis White, Producer
Expressions Video
Studio:
4983 Sunset Drive
Perrinton, MI 48871
Office: 517 323 8375
Fax: 800 231 7959
http://www.expressionsvideo.comMatt Mullen replied 16 years, 10 months ago 2 Members · 18 Replies -
Art White
October 28, 2009 at 2:55 pmHow do I get it in the presets? As a stand alone, it will only export as a targa file…unless I’m doing something wrong.
Expressions Video
Studio:
4983 Sunset Drive
Perrinton, MI 48871
Fax: 800 231 7959
http://www.expressionsvideo.com -
Matt Mullen
October 28, 2009 at 3:05 pmTo access the presets go to the windows menu and choose Library Browser.
Not being able to export a .mov is normal with FX standalone. Being able to export standalone is a function you gain with Boris Red!
-Matt
Art White
October 28, 2009 at 4:28 pmNow I know!
Looks like I have to download the latest update to add Boris as a plugin for CS4Artis White, Producer
Expressions Video
Studio:
4983 Sunset Drive
Perrinton, MI 48871
Fax: 800 231 7959
Matt Mullen
October 28, 2009 at 6:25 pmHey Art,
My e-mails seem to be getting delayed…so I’m going to post those instructions here for you on how to use the filters with Premiere:
Applying a Boris Effect as a Filter
1.
Select a clip in the timeline.2.
In the Project window, click the Effects Tab, and expand the Video Effects folder.3.
In the 3rd Party Folder, drag the Boris filter plugin onto a clip in the Timeline.
The Boris user interface opens.4.
Create your effect by choosing one of the many Boris effects from the Filters menu, or choose a premade settings file from the KeyFrame Library Browser.5.
When you are satisfied with the effect, click the Apply button on the bottom right of the Timeline. This returns you to the Premiere desktop.6.
Render your Boris effects the same way you would render any other effect in Premiere.—————————————————————–
Applying a Boris Effect as a Composition Clip1.
In Premiere, choose File > New > Boris Composition. The Boris user interface opens.2.
Create a Boris effect, and use it as a source in your Premiere Timeline for transitions and filters.3.
When you are satisfied with the effect, click the Apply button on the bottom right of the Timeline. You are returned to the Premiere interface, and a new Comp clip is placed into Premiere’s Project window.4.
Drag the Comp clip into the Premiere Timeline as part of your edit.5.
Render this the same way you would any other Premiere effect.——————————————————————-
Applying a Boris Effect as a Transition1.
Create In and Out points on the clips that will be part of the transition, and edit them into the Timeline.2.
In the Project window, click the Effects Tab, and expand the Video Transitions folder.3.
In the 3rd Party Folder, drag the Boris transition plugin between two clips in the Timeline.4.
Double-click the Transition icon in the Timeline.
This opens the Effect Controls tab in the Monitor window.5.
In the Monitor window click the Custom button to launch the Boris user interface. Be patient, as it may take several seconds to load.6.
Open a Transitions Settings file from the Boris Keyframe Library, or choose a transition effect from either the Filters > Wipe Transitions or the FEC Plug-ins category.7.
When you are satisfied with the effect, click the Apply button on the bottom right of the Timeline. You are returned to the Premiere interface.8.
Render your Boris transition the same way you would any other Premiere transition.——————————————————————
Tips for Using Boris Software with Adobe Premiere and Premiere Pro•When using a Boris effect that creates an alpha channel (such as a title, a shape that does not fill the screen, or a particle effect), the alpha channel appears black (rather than transparent) in the preview until you Control-click the effect in the timeline, choose Video Options > Transparency and in the Key Type menu, choose Alpha.
•Premiere is limited to two source track inputs. To use additional images and files, add the images directly within Boris software. Enter the Boris user interface and add unlimited tracks in the Boris timeline, importing movie and still image files, creating color, natural and gradient tracks and layering spline and text tracks over your effect.
•To display the Premiere sequence’s timecode in the Boris user interface, set the View Time menu in the General tab in the Preferences window to Program Timecode. You can open the Preferences window by choosing Boris > Preferences (Macintosh) or Edit > Preferences (Windows).
-Matt
Art White
October 28, 2009 at 7:20 pmI don’t see a 3rd party folder. I downloaded BLUE 2.5.2 and installed it.
Dell XPS 600
Pentium 3.20ghz 2.00GB ram
Geforce 7800 GTX -
Matt Mullen
October 28, 2009 at 7:23 pmArt,
Did you install Graffiti…Blue and Graffiti are two different pieces of software.
-Matt
Art White
October 28, 2009 at 7:59 pmI installed Boris FX 9.0 a few years back. It had a trial version of Graffiti 5.0 included
Art
Matt Mullen
October 28, 2009 at 8:11 pmerr…sorry I meant FX. As I mentioned before you need to install FX with the CS4 option…grab the most updated version from our updates page here: https://www.borisfx.com/updates/
Once you go to the link choose “FX” this will populate some options below.
The 2nd option Boris FX 9.3.2 Update for Boris FX 9.x Windows Users is the one you want.
Please download and install this then you should see FX in Premiere Pro
-Matt
Art White
October 28, 2009 at 8:38 pmThat takes away some of the confusion.
This is what I will do:Unistall Boris FX 9.0
Install update FX 9.3.2
Purchase download FX 9.3 upgrade for $199.00
FX will not work with Premiere CS4 unless I purchase the download?
Is that correct?
Expressions Video
Studio:
4983 Sunset Drive
Perrinton, MI 48871
Fax: 800 231 7959
