Activity Forums Adobe After Effects Boris Fx 6
  • Boris Fx 6
    Posted by Mcmohawk on February 24, 2006 at 3:29 pm
    hi
    im trying to make a 3d spherical cage using boris fx. I made the bars using white solids precomped. I then imported a texture picture which i then set underneath with the track matte set as alpha for the bars layer. However, when i then put a precomp of these layers into boris it does not recognise the track matte and just displays the texture picture. Does anyone know a way around this? I have also tried placing the texture layer above the bars layer with the blend mode set to stencil luma. However, when this is then put into boris all that is seen is the bars.
    Help!
    Cheers
    Mcmohawk replied 20 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
