Activity Forums Adobe Premiere Pro Boris Extruded Text Appearing Cropped
  • Boris Extruded Text Appearing Cropped
    Posted by Dougie Campbell on November 26, 2021 at 11:21 am
    I am using Boris on an iMac (Big Sur)with Premiere Pro 22. For some reason the original Boris FX text looks fine but when I change it to something else the text looks cropped. I typed in the phrase this is an example of text but as you can see it cuts off after the o. I tried shrinking the size but all that does is shrink the cropped text.
    Any advice would be gratefully received
    Dougie Campbell replied 4 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
