Activity Forums Boris FX Boris Continuum Complete 7.04 and Extruded EPS filter
  • Pero Peric
    October 2, 2010 at 9:29 pm
    Uuups, for picture 2 correct link should be:
    https://i157.photobucket.com/albums/t65/Warrior30/EPS2.jpg
  • Peter Mcauley
    October 4, 2010 at 1:20 pm
    The EPS file that you are attempting to extrude is rather complex and might require a slightly different workflow than a more standard EPS logo Illustrator file. To successfully generate the result you are expecting, I’d suggest that after you extrude the EPS file, you then disable the Keep EPS Color switch in the filter control panel and use the original illustrator file as a texture layer to map the original colors back onto the extruded result.
    I hope this helps.
    Cheers,
    Peter.
