Activity Forums Boris FX Boris CC 7.04 OFX repeatable crashes with W7 & Vegas 10.C
  • Boris CC 7.04 OFX repeatable crashes with W7 & Vegas 10.C
    Posted by Al Bergstein on February 18, 2011 at 5:13 am
    Ok. I’ve spent hours today, and I’m now sure there is a bug in Boris working with Sony Vegas 10.c. Is it something else on my computer? who knows.
    here goes.
    I was watching the seminar online today that Boris and John R. did . I tried to replicate something that John was doing with Boris, Vegas 10c. Here’s what I can faithfully replicated:
    Fire up a new instance of Vegas 10.c
    New timeline nothing on it.
    Create a new Video track.
    Create a new empty event.
    choose the FX icon on the event.
    Choose Boris FCC Extruded text.
    Do anything, like try and launch the text window.
    Bang…Vegas freezes up solid. Over and over again.
    uninstall Boris… all seems to work fine.
    Download a fresh copy from Boris. Reinstall… Same problem.
    Vegas goes into NOT RESPONDING mode.
    Windows 7 Home Premium 64 bit
    Intel Core Premium i7 870 @ 2.93 Ghz 8GB RAM
    Nvidia Gforce 9500 GT
    Alf
    Al Bergstein replied 15 years, 5 months ago 2 Members · 4 Replies
  • Al Bergstein
    February 18, 2011 at 8:02 am
    Whether it matters, a Vegas error message that comes with it.
    Extra Information
    File: C:\Users\Al\AppData\Local\Sony\Vegas Pro\10.0\dx_video_grovel_x64.log
    File: C:\Users\Al\AppData\Local\Sony\Vegas Pro\10.0\svfx_video_grovel_x64.log
    File: C:\Users\Al\AppData\Local\Sony\Vegas Pro\10.0\dx_grovel_x64.log
    File: C:\Users\Al\AppData\Local\Sony\Vegas Pro\10.0\vst_grovel.log
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 10.0c (Build 470) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\Program Files\Sony\Vegas Pro 10.0\vegas100.exe
    Fault Address: 0x0000000000000000
    Fault Offset: 0x0000000000000000
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 10.0\vegas100.exe
    Process Version: Version 10.0c (Build 470) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2011-01-03 (Mon Jan 03) 17:40:24
    I do have a crash dump (460 MBs or the like if you want it)
    Alf
  • Boris Yamnitsky
    February 18, 2011 at 10:43 am
    Alf, I can’t immediately explain that. We use similar systems in our lab. Are you using two monitors? Can you contact our support to see if we can solve this problem.
    Boris Yamnitsky
    BorisFX
  • Al Bergstein
    February 18, 2011 at 3:46 pm
    Yes, I use two monitors. I’ll .intact support this morning.
    Alf
  • Al Bergstein
    February 18, 2011 at 8:28 pm
    Ok. I decided to reinstall the NVIDIA software. That did the trick. My best guess is that I had only taken the default W7 NVIDEA drivers when I installed my card on this newer machine, (my HP motherboard fried after only one year in Dec), and had not tried Vegas since then (a few weeks back, and I had FCP to fall back onto). Boris tech support was very good, but we didn’t need to get into the depths of this. So the upshot is if you upgrade your computer but not your video card, make sure to get driver updates for the new machine. All appears well now, testing will continue.
    Alf
