Activity Forums Avid Media Composer Boris AVX won’t keyframe in Avid mediacomposer 3 on a Mac
  • Boris AVX won’t keyframe in Avid mediacomposer 3 on a Mac
    Posted by Niels Venrooij on February 5, 2009 at 8:57 pm
    I’ve installed Boris AVX 5.0.4. on Avid Media Composer version 3.1.2 on a Mac. And can’t seem to keyframe an effect in Boris. My other effects and plugins work fine. Usually you put on an effect and in the effect editor you have a starting and an end keyframe. When I open the effect editor I don’t see any keyframes. I can add them myself but I can change values for only one. If I change the values for the next keyframe, the previous values are lost. Pretty annoying if you’re trying to make a transition…
    Any help on this problem would be appreciated!
    Niels Venrooij replied 17 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
