Activity › Forums › Apple Final Cut Pro Legacy › Boris 3D titles blurry if not at even number?
  • Boris 3D titles blurry if not at even number?
    Posted by Ron Dylewski on February 15, 2006 at 8:25 pm
    Hi –
    I recently found that if I use the built-in Boris 3D titler to create a simple lower third, that they will look a bit blurry if they are not set (in the motion tab) at evenly divisible numbers. In other words, if I just drag the title to where I want it, it may land on some off number, like -121.03 — and this will not look as sharp as it would if this title were at -122.
    Is this just a quirk…or is it me…or…
    Ron
    Photos, news, memories and musings on the great American Roadside experience
    https://www.theamericanroadside.com
    Are you a collector? Put your collection online for free at What A Collection.com!
    https://www.whatacollection.com
    Ron Dylewski replied 20 years, 7 months ago 6 Members · 6 Replies
  • Chris Babbitt
    February 15, 2006 at 9:17 pm
    That’s correct, but it is only for either the vertical or horizontal, not both. I just can’t remember which one.
  • Bouncing Account needs new email address
    February 15, 2006 at 9:43 pm
    VERTICAL position must be at even integer.
    Horizontal position does not matter.
  • Arnie Schlissel
    February 15, 2006 at 10:22 pm
    If you use the control tab to set your position, you won’t have this problem. You won’t need to keep track of whether you’re on a whole, even integer or not. The same goes for any of FCP’s generators that let you change position in the control tab. When you set the position in the motion tab, you’re positioning the entire frame that the title is in, if you use the control tab, you’re only positioning the title in the frame.
    Arnie
    https://www.arniepix.com
  • Walter Biscardi
    February 15, 2006 at 10:41 pm
    [Arniepix] “If you use the control tab to set your position, you won’t have this problem.”
    This is absolutely correct information.
    en you use the FCP Motion tab to move the titles, they cease to be a Vector based graphic and instead are rasterized by FCP, thus degrading the title.
    If you use the Boris Control Tab to position the graphic, it remains vector based and yields a very clean title.
    It takes some getting used to, but once you get the hang of it, you can type in some numbers pretty quick.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Kevin Monahan
    February 15, 2006 at 10:45 pm
    Amen, the voice of reason.
    I extol the virtues of using the controls tab to set type position in my book as well.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
  • Ron Dylewski
    February 16, 2006 at 1:41 pm
    Hi All –
    Thanks so much for the great info. This really clears up the issue for me.
    Now my titles will look a lot better, so my clients thank you as well!
    Ron
