Activity Forums Adobe After Effects Boris 3D shatter
  • Boris 3D shatter
    Posted by Mcmohawk on May 2, 2006 at 6:21 pm
    hi,
    Im trying to use the 3d image shatter in boris 6 but im stuggling with how to delay the shatter until later in the composition. It shatters at the start whereas i need the shatter to happen around 30 seconds in.
    what am i doing wrong?
    Aharon Rabinowitz replied 20 years, 4 months ago 2 Members · 1 Reply
  • Aharon Rabinowitz
    May 3, 2006 at 1:09 am
    If this is a still image, The absolute easiest (but not the most efficient) way is to duplicate the layer you are shattering and remove the shatter effect from one of them. Then do a swap out. Up until you want the shatter, use the non-shattering layer. At the moment you want the shatter layer, trim the non shtter layer out, and move the shatter layer’s in point to that frame.
    If it’s video, or you just want to do it more efficiently, you’ll need to set the shatter effect to animate, as such:
    At frame 0 set force 1 to have a depth of 1.
    Set a keyframe for that property.
    Make it a hold keyframe.
    At the first frame you want the shatter to occur, set the depth to .1, the default depth value.
    Your layer will then shatter.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
