Activity Forums Apple Final Cut Pro Legacy Border Problem in FCP
  • Border Problem in FCP
    Posted by Ross Geddes on January 17, 2010 at 5:34 am
    Hi Guys
    I am putting together a wedding and want to break up each section with a 16:9 photo from the wedding and a title placed in the bottom left.”ceremony,speeches,” etc etc.
    I get the photo and import. I shrink it a little and then add a border. All good. However when i add a livetype text movie over the top, it cuts 1/4 of the border off from the right side. I have tried everything i can think of but nothing seems to fix the problem. It seems I can’t have a full border with text in FCP??
    Can anyone offer any suggestions?
    Ross
    Ross Geddes replied 16 years, 8 months ago 3 Members · 3 Replies
  • John Fishback
    January 17, 2010 at 11:32 pm
    Try exporting the shrunk & bordered pic, then import that and place it on v1. Then put the LiveType on v2. You could also try making a freeze frame of the shrunk & bordered pic and do the same thing.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Andy Mees
    January 18, 2010 at 12:31 am
    Ross
    Have a bash with my Simple Crop plugin, its meant to make sticking a border on a cropped clip easier but should work for adding a border with or without cropping. It may or may not evidence the same issues as you’re already seeing but its possibly worth a try (its free).
    https://web.me .com/andymees
    Best
    Andy
  • Ross Geddes
    January 21, 2010 at 2:11 am
    Hi guys
    Thank you both for taking the time to reply. I’ll try your suggetsions John and Andy, you are a champion – i’ll give your plugin a go.
    Cheers
    Ross
