Activity Forums Maxon Cinema 4D Boolean Problems
  • Boolean Problems
    Posted by Glenn Takakjian on June 19, 2005 at 5:42 pm
    I’ve been having trouble with my booleans… v.9.1. With many objects if I use the High Quality setting the Boolean doesn’t do anything. If I turn off the High Quality setting the boolean makes the cut but I am unable to access the other options like Make Single Object etc.
    I didn’t have this problem with v.8 Is this a bug?
    TAK
    Brian Jones replied 21 years, 3 months ago 2 Members · 1 Reply
  • Brian Jones
    June 19, 2005 at 9:11 pm
    can you post an example scene? I can use ‘many’ and it works with or without High Quality checked but maybe I am not using many enough.
