Boolean: opposite of A intersect B
Ok, picture a broom handle and then slicing an end off at a 45degree angle.
I was trying to use a boolean with a cylinder and a plane rotated at 45.
The option of A intersect B with the Cylinder as A and the plane as B is the exact opposite of what I’m trying to do.
Is there an easy way to do this besides the more meticulous of editing points? Keeping a radius while editing points is proving to be quite a task
