Activity › Forums › Maxon Cinema 4D › boole problem
  • boole problem
    Posted by Emmet Reddy on January 11, 2010 at 10:55 am
    Hi all, I want to create a reveal text effect, so i have a cube and a text with extrude inside a boole, the cube is covering the text i animate the cube to the right revealing the text the cube is invisible because its inside the boole it seems to be working fine but when i render, the text comes into full vision every few frames like the boole is not working properly? not sure if i have explained myself very well heres a link to the file. Thanks Emmet
    465_booleguide.mov.zip
    Adam Trachtenberg replied 16 years, 8 months ago 3 Members · 3 Replies
  • Brian Jones
    January 12, 2010 at 1:32 am
    uncheck High Quality in the Boole, it will slow it down but it will work the way you expect.
  • Emmet Reddy
    January 12, 2010 at 10:58 am
    Thank you very much.
    Emmet
  • Adam Trachtenberg
    January 12, 2010 at 2:36 pm
    If you have MoGraph, a faster/cleaner way to do this is to use Spline Mask to perform the boolean with splines rather than on the extruded object. Then extrude the Spline Mask object.
