Activity Forums Maxon Cinema 4D Boole and mograph, do they work together
  • Boole and mograph, do they work together
    Posted by Olly Bea on September 20, 2007 at 10:53 am
    Hey.
    Thought this was a simple project, but it turns out to be a bit of a head scratcher.
    I have created a simple boolean shape where a sphere is cut out of a cube (I will call this ‘bowl’).
    Secondly I have created some mograph text and warped it using a spline warp (found under the mograph tab) which matches the contours of the bowl.
    I want to ‘cut out’ / ‘engrave’ the text from the bowl, but whenever I use the boolean tool it doesn’t work.
    Does boolean shapes and mograph text not work together? Is there another way to achieve what I want? Any help would be gratefully received.
    Olly
    Olly Bea replied 19 years ago 2 Members · 2 Replies
  • Adam Trachtenberg
    September 20, 2007 at 3:59 pm
    I tried it and it works fine here. Your heirarchy should be:
    Boole
    ..Boole
    ….Cube
    ….Sphere
    ..Text Object
  • Olly Bea
    September 21, 2007 at 8:27 am
    Got it to work in the end, thanks Adam.
