Activity › Forums › Adobe After Effects Expressions › BODYMOVIN with sourceRectAtTime
  • BODYMOVIN with sourceRectAtTime
    Posted by Gustavo Duque estrada on March 25, 2021 at 1:04 pm
    I have made a simple composition with a Text and a Shape Layer with responsive resized by the text layer. I used the sourceRectAtTime expression into the shape layer to follow the text size.
    When i export with Bodymovin to HTML, the final file doesn’t understand the expressions correctly.
    Does Anyone knows if this is possible to works properly? If the bodymovin understand the sourcerectattime expression?
    if you look at the screenshots you will see that html doesn’t understand correctly the expresstions.
    Gustavo Duque estrada replied 5 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
