Activity Forums Maxon Cinema 4D Body Paint Problem
  • Body Paint Problem
    Posted by Fraser Bray on May 13, 2005 at 7:37 am
    Hi, wonder if you could help… Since Ive upgraded from BodyPaint 8 to 8.207, I have been experiencing trouble with my palletts and texture view.
    1. I cannot find the UV Rotate, Scale and move tools. (Under “UV tools” it shows that R is the shortcut to UV Rotate, but it goes straight to Rotate active element.)
    2. My Layer Manager only has the word Layer on the tab, (so im not sure if it is the same tab) and it does not allow me to drop a texture onto it.
    3. When i drop my texture onto the name of my object in the objects manager, no “Texture dialog Box” pops up.
    4. I cannot see my texture in the texture view. This is my biggest problem…In the tutorials for example the red dot bmp can be accessed in the Texture view under “Textures” (Option- Empty canvas or….bmp?) I have created a TEX folder and a tex path to my bmp and yet i can still not see it in that window.
    I can apply my bmp to my object and i can distort my UV MAP and it works real time on my object, but there is no image in that view, just a grey square.
    Thank you for providing this service!
    Fraser Bray replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
