Activity › Forums › Blackmagic Design › BMD video playback is not available in Premiere Pro CC
Ken Hall replied 12 years, 11 months ago 6 Members · 18 Replies
Ericbowen
August 10, 2013 at 5:55 pmOk you may need to Re-install the Adobe suite then. I have never seen that greyed out. Make sure you uninstall the Blackmagic before you do.
Eric-ADK
Tech Manager -
Neil Sadwelkar
August 11, 2013 at 12:08 amAfter Creative Cloud, re-installing PrPro, is not easy. Huge download.
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India -
Ken Hall
August 12, 2013 at 6:10 pmThis morning I uninstalled the BMD drivers, then uninstalled Premiere. I downloaded and installed the latest version of the Adobe Cloud Manager. Next, I downloaded and installed the latest version of Premiere. Before I installed the BMD drivers I launched Premiere and looked at the settings for Playback. There were three options, Adobe DV, Adobe Monitor 1 and Adobe Monitor 2. All were grayed out and none could be chosen.
I then installed BMD desktop video 9.7.7. I re-launched Premiere and looked at Playback Preferences. The system showed Blackmagic Playback as well as the three Adobe options. All were still grayed out and none could be chosen.
Ken
Alex Gerulaitis
August 12, 2013 at 7:50 pm[Ken Hall] “I then installed BMD desktop video 9.7.7. I re-launched Premiere and looked at Playback Preferences. The system showed Blackmagic Playback as well as the three Adobe options. All were still grayed out and none could be chosen.”
Have you tried resetting Premiere Pro preferences? (Re-install may not have cleared them.)
“To restore default preference settings, hold down Alt (Windows) or Option (Mac OS) while the application is starting. You can release the Alt key or Option key when the splash screen appears.”
(Sorry if this has already been tried and/or suggested.)
Ken Hall
August 12, 2013 at 8:53 pmAny suggestion at this point is good, thanks. And yes, I did delete Premiere prefs when I uninstalled the app.
Ken
Jeff Handy
September 28, 2013 at 4:48 pmDid you ever get this resolved? What was the solution?
HandyGeek
Ken Hall
October 3, 2013 at 6:01 pmYes, the issue was resolved. In the Program Monitor pull down menu is a function called “Transmit”. When enabled the signal is output to an external monitor. When disabled, nothing goes out. Somehow I had disabled Transmit through some unknown key stroke combination.
Ken
