Activity Forums Blackmagic Design BMD SP & sync…
  • BMD SP & sync…
    Posted by Chemix Ferreiro on July 22, 2005 at 5:24 pm
    Hi all, just popped in the BMD SP, wired it up w/ the UVW 1800P and, capture FINE but when playing back… no sync
    Where do I need to plug in the GENLOCK IN cable? I do not have a sync generator (I thouhgt I would not need it since all I have is 1 deck and 1 broadcast monitor…)
    Chemix Ferreiro replied 21 years, 1 month ago 2 Members · 3 Replies
  • Chemix Ferreiro
    July 22, 2005 at 5:25 pm
    Thanks a lot in advance for any clues…
    (OOPS)
  • Kristian Lam
    July 23, 2005 at 12:26 am
    Connect the Y-component output of the card to your deck’s REF IN, then take the loop out from the reference back into the deck’s Y-component inputs. That way, the deck can use use the video source as a sync reference. Remember to toggle the termination switch next to the connectors on the deck.
    Kristian Lam
    Blackmagic Design
    regards
    Kristian
    Blackmagic Design
  • Chemix Ferreiro
    July 23, 2005 at 9:59 am
    thanks a lot for the info. here in the canary islands we dont have that many sources for technical input.
