Activity › Forums › Blackmagic Design › BMD HDPRO non-broadcast? Mediocre jitter test result !
  • Steve Connor
    October 20, 2005 at 6:27 pm
    [eduardo sousa] “What are the real world implications if you want to record the signal ?
    Is the Board only broadcast for monitoring and not for high-end playout ?”
    Is that a serious question – really? Well if Matrox say it’s true I guess it must be, better throw out our HD Pro!
    Steve Connor
    Cardinal HD
    Please fill in your profile – it helps US to help YOU!
  • Eduardo Sousa
    October 20, 2005 at 11:30 pm
    from your answer I can only guess that you haven`t read the article.
    And I am assuming the “mediocre” jitter test has no real world implications.
    It is interesting no note that a previous post on this subject “HD Stability” made by someone else, so far , got no anwsers.
  • Shane Chadder
    October 21, 2005 at 2:58 am
    Yes read the article….
    “We deliberately used unnecessarily long cables, took
    no care to keep video feeds away from mains supplies, looped
    the signal through a monitor or two and a couple of patchbays.”
    So if you are going to be sloppy with your cabling it might be worth spending the extra what is it $6000-$8000 or so?
    Hey I like Matrox products. Digisuites performed well for years for us. But this seems like a “test” aimed directly at Black Magic. I’d like to see the numbers for two properly cabled systems.
    If I buy an Axio it will be because of the real time abilities, not the jitter “test”.
