Activity › Forums › Blackmagic Design › BMD Codec v4.8 crashes Digital Fusion
  • BMD Codec v4.8 crashes Digital Fusion
    Posted by Adrian Tecson on February 20, 2006 at 7:42 am
    I installed the v4.8 of the BMD codecs today cause I wanted to be able to export directly to BMD Avis in Digital Fusion. Problem was after installing the codecs, Fusion would lock up upon import of the 10bit digitized AVI files. The codecs actually werent required to view and work with the AVI files, since I could do composites even without the codecs installed, after which I’d render out in an image sequence instead of an AVI. But now that I was AVI outputs, Fusion hangs when the codecs are installed. Is there a link to the old set of codecs so I could test them out?
    Adrian Tecson replied 20 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
