  • Posted by Oliver Peters on July 30, 2020 at 5:31 pm
    From todays’ live stream:
    New Streaming Bridge box to connect your ATEM Mini Pro output via ethernet to another location. Used to feed monitors, projectors, etc. Also possible to connect switcher to Streaming Bridge anywhere in the world via internet.
    New ATEM Mini Pro ISO. New version that includes built-in ISO recording of each input, plus switched feed to an external USB drive. Total of 5 files.
    The ISO model also generates an “EDL” from the live switch that opens in Resolve, syncs the ISO H264 angles, and allows you to clean up/re-edit the recorded event. If you also used BMD cameras and recorded BRAW in-camera at the same time, then Resolve can relink to the BRAW files instead of the H264 ISO files for final mastering. Resolve update out today.
    – Oliver
    Oliver Peters – oliverpeters.com
    David Sikes replied 6 years, 1 month ago 4 Members · 3 Replies
  • Steve Connor
    July 30, 2020 at 9:04 pm
    [Oliver Peters] “New ATEM Mini Pro ISO. New version that includes built-in ISO recording of each input, plus switched feed to an external USB drive. Total of 5 files.
    The ISO model also generates an “EDL” from the live switch that opens in Resolve, syncs the ISO H264 angles, and allows you to clean up/re-edit the recorded event. If you also used BMD cameras and recorded BRAW in-camera at the same time, then Resolve can relink to the BRAW files instead of the H264 ISO files for final mastering. Resolve update out today.”
    Very impressive, when events finally come back this is going to be VERY useful for some of the work I do
  • Glenn Grant
    August 1, 2020 at 5:27 pm
    I’m hopeful the ability to record the Resolve Project file along with the Program master finds it’s way to the ATEM Mini Pro. It would be great to have that file and then sync camera originals.
  • David Sikes
    August 3, 2020 at 4:03 pm
    [Oliver Peters] “The ISO model also generates an “EDL” from the live switch that opens in Resolve, syncs the ISO H264 angles, and allows you to clean up/re-edit the recorded event. If you also used BMD cameras and recorded BRAW in-camera at the same time, then Resolve can relink to the BRAW files instead of the H264 ISO files for final mastering. Resolve update out today.”
    I missed this part of the announcement! That’s pretty awesome. While I love our ATEM Mini Pro and have no interest in paying for the upgrade, if we were buying today this bit would be a hard feature to say “no” to.
